Simcenter 3D API: Creep Curve Fitting App
Siemens Theorist Siemens Theorist
Siemens Theorist
Utility Name
Creep Curve Fit App
Summary
Computation from test data of the Bailey-Norton creep law coefficients
Detailed Description
This App allows by means of a dedicated UI the user to:
  • select one test data file,
  • run the curve fitting tool in order to compute the 3 Bailey-Norton creep law coefficients,
  • plot the resulted curves against the test data points for quality checks,
  • update the material with the computed coefficients.
General Information
Compatible versions
Source code
Keywords
Simcenter 3D 2019.1
dll
Bailey-Norton, Creep law
Known Issues
None
Test Case
  1. Launch Simcenter 3D
  2. Open a .fem file
  3. Type Ctrl-u in order to browse and select curve_fit_app.dll in NX/application
  4. Enter the parameters (.csv test data file, …)
<-- Test data file (.csv)
<-- Format of test quantities
<-- Possibility to subtract the elastic strain
<-- Model coefficients initial guess
<-- Possibility to update the Nastran material
<-- Output file & folder selection
    5. Click on Compute Coefficients
    6. Model coefficients as a function of Temperature are shown in Information window
    7. Test data & resulting curve are displayed in Graph window
Author
Easwaran Viswanathan
3D Customization team for updates
@OliverZ
