Simcenter 3D API: Cyclic Symmetry
Siemens Legend Siemens Legend
Siemens Legend
Utility Name
cyclicSymmetry
Summary
Support cyclic symmetry in NX CAE.
Detailed Description
Starting a Cyclic Symmetry Simulation from NX CAE. Cyclic Symmetry is supported in NX Nastran but NX CAE does actually not support the Preprocessing.
General Information
Compatible versions
Source code
Keywords
NX 9.0
VB
Cyclic symmetry,  simulation
Known Issues
None
Test Case
This program must be executed in a .fem part.
DLL instructions:
  • Run this program from within a FEM file in NX Advanced Simulation
  • Use 'Developper > Play' to run cyclic_prep_and_start_sol114.vb
  • Files are generated next to .fem file.
Author
@BorisL
Comments
is the present API replaced by current functionalities in NX (1851 at the moment)?
i.e. use a 2D dependant mesh in the sim and the "cyclic symmetry simulation object" in the SIM (for a SOL402)?
I intend to use the cyclic symmetry preparation and post treatment in order to have a small model, for non linear analysis, with contact, material NL, bolt preload (not for modal or frequency analysis).
I'm looking for examples (or an update of the book Engineering Analysis with NX Advanced Simulation) of the use of cyclic symmetry with NX (1851). I cannot find explicit samples in NX documentation.
best regards,
best regards,
