Simcenter 3D API: Design Table for Motion
Siemens Enthusiast Siemens Enthusiast
Siemens Enthusiast
Utility Name
Summary
Create a Design of Experiments (DOE) with minimum user interactions, to evaluate and compare different sets of Geometric and Motion parameters.
Detailed Description
See the attached Design table for motion - FAQ.pdf
The version V1.1 for Simcenter 3D 2019.1 (and Simcenter 3D 12) contains many improvements and bugs correction
(See attached release-note.txt )
General Information
Compatible Simcenter versions
Tool version availability
Library/Executable
Keywords
Simcenter 3D 11
Simcenter 3D 12
Simcenter 3D 2019.1
V1.0
V1.0, V1.1
V1.1
EXE
Motion, Design Table
Known Issues
The code supports some errors: geometric invalid values (NX cannot update), Motion convergence error…etc.
But please contact me in case a scenario is not working on your side.
Test Case
See Design table for motion - FAQ.pdf
Sources
The tool sources can be requested by email to the Author.
In return, we would be grateful if you could share with us few information, such your company name, your business segment and a short description of your objectives/modification needs around the tool.
Author
@AlexP
