Simcenter 3D API: Hyperelastic Curve Fitting App
Siemens Theorist Siemens Theorist
Siemens Theorist
Utility Name
Hyperelastic Curve Fit App
Summary
Computation from test data of the Hyperelastic Material coefficients.
Detailed Description
This App allows by means of a dedicated UI the user to:
  • select one hyperelastic material model (either Noe-Hooke, Mooney-Rivlin, Polynomial, Ogden, Aruda-Boyce or Ogden Foam)
  • select test data file(s) (either uniaxial, equibiaxial, simple shear, pure shear or volumetric)
  • run the curve fitting tool in order to compute the model coefficients,
  • plot the resulted curves against the test data points for quality checks.
General Information
Compatible versions
Source code
Keywords
Simcenter 3D 2019.1
dll
Hyperelastic, Elastomer, Foam
Known Issues
None
Test Case
  1. Launch Simcenter 3D
  2. Type Ctrl-u in order to browse and select HyperElasticCurveFitUI.dll in NX/application
  3. Enter the parameters (choice of a Material Model, .csv test data file, …)
<-- Model selection
<-- Units
<-- Choice: either Distortion or Volumetric test
<-- Test data format
<-- Files & Initial value(s)
<-- Test data: .csv files
<-- Parameters for convergence
    4. Click on Compute Coefficients
    5. Model coefficients are shown in Information window
    6. Resulting curve vs test data are displayed in Graph window
Author
Easwaran Viswanathan
3D Customization team for updates
@OliverZ
