NX Plotting of Fibersim created Plybooks to a .pdf - in sheet number order.
NX drafting: Export to a plybook: Menu: File>Export>PDF.... you get the option to sort the sheets with the up/down arrows  and highlight those sheets to be added to the .pdf.
It is frequently the case: You just want to plot the sheets in the sheet number order (if you dont change any sheet number this the from Fibersim creation order..)
Also you may wish not to plot the Fibersim template sheet..
- a simple To_pdf_sheet_order.vb should be attached. You can change to suit your purposes.
Run as a journal.
Re: NX Plotting of Fibersim created Plybooks to a .pdf - in sheet number order.
rename file as .vb and run as a journal
