Video: Adding Custom Columns to Fibersim’s Material Database
Community Manager
(view in My Videos)
Within the database you might have seen a tab that says “custom”. Within this tab, you have some columns that say “custom 1, 2, 3, 4, 5… “ the intention of these columns are to extend your database to add information data to if that may not have a place in the rest of the members in the database. In order to accommodate your company and your specific process, you might need another field or set of data stored within the database and then documented later within Fibersim documentation capabilities. The way to do this is to leverage these custom columns. Check it out, as our Fibersim Product Manager, Marc Attar shows you how it’s done.
