Change Admin on MindSphere account?
We would like to change the admin on our existing MindSphere Developer account (from what it was originally set to in our contract and tenant agreements).  How do we do this?  Do we send an email to info@MindSphere.io?
Re: Change Admin on MindSphere account?
Community Manager
Hi @Mcadb_IoT, you can add and remove new admins through the IoT Data Modeler application on your dashboard. Simply remove the user you no longer want to be added. The original admin, the so-called "technical user" is the first admin granted and the only difference to the other admin roles is that he receives the downtime and other tenant related information. If you want to change the E-mail on your technical user, you need to request this change via email to contract@mindsphere.io.
Thanks @dvidflrmnd it was the second part that we want to change, so I'll send an email to the contracts distribution to have them change.  Thanks.
