Circular Pattern for Drawing
PLM World Member Experimenter PLM World Member Experimenter
How to use circular pattern in a Drawing Sheet using VB.Net?
In SDK I found the example use Circular PAttern for Part Documents.
But manually it is possible to use circular patterns in Drawing Sheet.
Please provide any sample code for using Circular Pattern in Drawing Sheet.
Thank You
Since you posted this in the Community Q&A instead of any...
Since you posted this in the Community Q&A instead of any specific product Q&A section and failed to mention what product you are asking questions about, I doubt anyone will be able to answer accurately.
I suggest you move this to the appropriate product Q&A section (Solid Edge or NX).
Production: ST10 MP9, Testing: SE 2019
http://Grundey.blogspot.com
Try Solid Edge for free
