Desigo data on Mindsphere
Siemens Desigo is the Building Management software. It has all the data of a building systems such as Fire Alarm, Access control, HVAC, and CCTV.
Are there any ready available analytics developed, in Mindsphere, to produce any actionable analysis using above data?
If not,
- is underway?
-if planned, when is it expected?
Thanks!
3 REPLIES 3
Betreff: Desigo data on Mindsphere
Hi AB9,
right now the App-Marketstore isn't available. The Plan is to release the Store with the MindSphereV3.0 at the beginning next year.
But you can take a look at the planned apps, which will come in the near future.
Here is the Link to the planned Apps:
https://www.plm.automation.siemens.com/store/en-de/mindsphere/apps/index.html
I hope that will help you.
See you,
Steffen1
Dear,
How far are we with this solution on V3?
Tnx - Hans
The MindSphere store is available. You can find it under:
https://www.dex.siemens.com/?selected=mindsphere
For the apps, you can find it under Applications:
https://www.dex.siemens.com/mindsphere/applications?viewState=ListView&cartID=&portalUser=&store=&cc...
See you,
Steffen1
