Fleet Manager - app service unavailable?
We've been getting the "app service unavailable" message intermittently in our tenant.  Is this something related to our instance only or is it a known MindSphere issue right now?  If a known issue, any timeline for resolution?  We are also submitting a Siemens support ticket...
Re: Fleet Manager - app service unavailable?
Community Manager
Hi, Mcadb_IoT, this is a common issue if a connection issue appeared and the connection to the platform is lost. This might happen due to an unplanned short notice maintenance, internet loss or a slow connection.  Your current issue is probably related to a slow connection, and this timeout-issue will be solved with next Fleet Manager release by end of this month. Till than as workaround: direct shortcuts to the extensions should help.
