cancel
How to remove the registed app
        I could register application to MDSP Home page. But how to remove the registed app? It seems only support to add ,but not support remove
Re: How to remove the registed app
Community Manager
@yuhe I checked this for you and right now we do not have this funtion in the system. The team is aware of that and will add the functionally with one of the next releases. Until then, the only way to remove an app from the home page/dashboard is via the official developer support hotline.
@yuhe We can't remove registed app by using UI but we can delete an application by calling ApplicationRegistry API.
The basic steps are:
- List all application, get the application id and Etag
- Send delete request to :  {tenantURL}/ApplicationRegistry/api/applications/{id} with X-CSRF-Token and If-Match params
if the delete request is successed, the response with 204 will return
