MindSphere data types range
Siemens Creator
Hello everybody;
As definining a new datapoint in MindSphere V3 for a MindConnect Nano, there are 5 types: int , long, double, boolean and string. I would like to know the range of values for these types. It is sure that type boolean is true / false (so it have a 1 bit range) and string have a variable size, but what about int, long and double?
And as a continuation, it seems than double is the only way to upload decimal values. So, how big (positive and negative) and how little (I mean 0.00000xxxx) a number can be represented?
Thanks for your answers.
Jose Vte. Romero
Re: MindSphere data types range
Siemens Creator
Hello everybody;
MindSphere Support send me this data reference for S7 data:
Hope this help you.
Best regards;
Jose Vte. Romero
