Mindgate is down?
I'm unable to do anything with MindSphere now. Each time when I try to access my app via IoT dashboard or calling API (both via Mindgate and approuter). I see the message :
404 Not Found: Requested route ('MindGate.appsdev.mindsphere.io') does not exist.
Does anyone have any ideas?
Re: Mindgate is down?
@TungNT the DEV platform is currently down and the team is working on resolving it now - so that's what is causing your 404 errors.  We'll follow up once we get notification that everything is back online.
I would suggest a MindSphere Dashboard with a list of all MindSphere services and their current state (like the dashboards for Google services and Amazon Web Services).
Because most users will first check their responsibilities when the find a MindSphere outage. It will save a lot of time when you can see that it is not your fault.
