OAuth Authorization Server – API Problems
I am trying to get an Bearer Token for my Mindsphere App over the OAuth API over Postman.
I used the following: https://{tenantName}.piam.{region}.mindsphere.io/oauth/token
I used my normal login creditentials with Basic Auth and added grant_type = client_credentials als form-data.
But i always get an 401 Unauthorized error.
3 REPLIES 3
Re: OAuth Authorization Server – API Problems
how did you solve it?
Siemens Genius Siemens Genius
Siemens Genius
In order to use the oAuth API you need special service credentials as described here: https://developer.mindsphere.io/howto/howto-selfhosted-api-access.html
You WebKey credentials are not going to work.
Yep, I realized it later.
