Problems to visualize assets properties in URL minddemosales.apps.mindsphere.io
Dear colleages
Today I have no possibility to create e new asset or access to view the asset porperties that is created in the IOT Data Model url minddemosales.apps.mindsphere.io.
The error shown is the image I attach...
Has someone the same problem ?
Thanks in advance
Re: Problems to visualize assets properties in URL minddemosales.apps.mindsphere.io
Siemens Genius Siemens Genius
Siemens Genius
@OKTOBER that 500 error code often points to a SAP platform issue - we were experiencing it the last few days and that is why they took the LIVE system down yesterday for 1.5 hour unplanned outage.  After that update I verified on my tenant that the 500 error codes are now resolved.  Can you let me know if you still see it now/tomorrow...and the steps you are taking to trigger that code if so?
@Mbossom Thanks, The system is ok again and the 500 error codes are not displayed.
