Problems with MindSphere
Siemens Creator
I am having problems with an asset of a MindConnect IOT2040. This morning it was not uploading data to MindSphere. I have offboarded the asset and onboarded it again. The file of the USB says it is onboarded, but in MindSphere stills appears the message "Onboarding" and it is not uploading data.
Re: Problems with MindSphere
Community Manager
Hi @Laura_ES,
thanks for getting in touch. MindSphere has a weekly maintenance on Thursday so your issue might have indeed been affected by todays early maintenance. Since I am not entirely sure what happens when you try to onboard machines during such a maintenance windows, I´d recommend you restart the onboarding again now, since the maintenance is completed.
By the way, you can always keep track of the planned downtimes in this posting here.: https://community.plm.automation.siemens.com/t5/Developer-Space/MindSphere-Planned-Performance-Updat...
I have experienced similar issues in the past where my IOT2040 was showing on-boarding state in MindSphere but the LEDs on the unit were green.  In one case I removed the onboarding USB, and it then went online.  Tough to say what ultimately caused this one.  The other scenario where it was the firmware version (I think) - I did not have the firmware update schedule enabled and because there was a new version available the unit did not on-board.  When I enabled the schedule I could see in the log files that the firmware updated and it then showed online.
Hope this helps.
Siemens Creator
Thanks @Mcadb_IoT!
Today has been working! I think it was a platform maintenance!
