Required & conventions to Promote application from Developer Tenant to Operator Tenant
Hi All,
I would like to open a discussion to share experiences when you promote an app from Developer tenant to Operator tenant on MindSphere V3, key points as below
  1. Create new application: app and component naming conventions.
  2. How to package your source code and define single yml file to work with MindSphere's process
  3. Required and validation time when upload binary source
  4. Deployment application on Operator tenant includes: space name, services, multiple apps use the same backing services issue...
  5. Other issues
We can discuss, make the flow better and take minimum risks for the deployment time
Thank you
Hoang Doan
