Retrieve Data from mobile application
Hello everybody,
We are creating a mobile application that needs to get data from Mindsphere. We have developed a MindSphere app with some REST API's that return some time series from the database. It actually works when we access the endpoint from any browser like Chrome, but when I try to access the same endpoint from my mobile application (developed in Ionic, if it helps), I get a CORS error:
Invalid CORS request
Access to XMLHttpRequest at 'https://*********.eu1.mindsphere.io/gettoken.php' from origin 'http://localhost' has been blocked by CORS policy: Response to preflight request doesn't pass access control check: No 'Access-Control-Allow-Origin' header is present on the requested resource.
I've search a lot but I didn't find anything useful. and many discussions are old, or the links are broken, that is why I'm opening a new discussion.
Is there any way to access the data from MindSphere from a mobile Application using REST API's??
Thanks for the help,
Carlos Roig
Re: Retrieve Data from mobile application
Siemens Creator
Error can be resolved by adding A-C-A-O header in MindApp API response.
Sample code snippet:-
HttpHeaders headers = new HttpHeaders();
headers.add("Access-Control-Allow-Origin", "*");
return new ResponseEntity<>(<responseBody>,headers,HttpStatus.OK);
Since accessing MindApp API from postman without interceptor being tried and getting same CORS error.
Enabling interceptor resolves this error from postman.
