SSH connect to PostgreSQL service instance
Hi All,
I would like to share the guideline how to make SSH connection to PostgreSQL service instance on Cloud, and you can do a rapid development with PgAdmin 4 from local.
  • Get application environment info:  cf env appName
  • Take note
         Host, name, username, pass
  • Connect by ssh command:
          cf ssh appName -L 5433:host:5432
          -L: 5433 for local port server setup
  • Connected and query as local database
  • Disconnect SSH by exit command
Hope this helpful for your development
Hoang Doan
13 REPLIES 13
Re: SSH connect to PostgreSQL service instance
Hi
Thanks for the info. This is exactly what I did yesterday and got it sorted. Anyways kudos for sure for the reply. Smiley Happy
Thank you Sajan
We have tried the following command:
However facing some issues here.
Error opening SSH connection: dial tcp <some_address>: connectex: A connection attempt failed because the connected party did not properly respond after a period
of time, or established connection failed because connected host has failed to respond.
Could you please let me know what could be the cause of this ?
The following image has the Error displayed for reference.
Hi @MansiHundlani
Make sure your space and app are allowed ssh connection, try this one
cf allow-space-ssh SPACE-NAME
$ cf enable-ssh MY-AWESOME-APP
https://docs.cloudfoundry.org/devguide/deploy-apps/ssh-apps.html#enable-disable-ssh
Hoang Doan
Thanks for information.
I have some issue :
when i am logged through SSH tunnel to postgresql with my user i dont have previledge for delete schema,insert
data,create roles and view data in pgadmin4.
Priviledge shows for my user :
1)can login.
2)can inherit rights from the paarent roles.
So is there any option to resolve this.
Thanks in advance Smiley Happy
Hi @HoangDQ,
I tried your port forwarding/tunneling  solution. This work well when i am not in siemens network but it not work when i am in siemens network(due to siemens proxy). Could you please help me out ?
I am trying to connect mongodb service instance on mindpshere.
Hello @HoangDQ
I am also getting ssh connection issue, for my tenant space and application ssh already enabled, could you hepl me out.
Uppala Ravi
Just FYI, after the MindSphere Developer Days in Berlin last week, we have released an OSS demo project. Part of it is a script and documentation on how to perform such operations:
https://gitlab.com/mindsphere/devops-demo/blob/master/tools/README.md
@bufferoverflow
Siemens Creator
Hi HoangDQ,
     Thanks for your info, I also desperately need a DB tool.
     Here, I have a question, you had bind the DB instance with an app, and through 'cf env app' get the instance info. If my db instance don't bind any app, how to use the tool bind mindsphere db instance?
