Re: SSH connect to PostgreSQL service instance
@yuhe It's mandatory to bind your service db to an application, you won't be able to reach it otherwise. In your sample you are trying to ssh and then create a tunnel port, are you even able to ssh directly to the sqltool app? The error you get points to the answer being no.
Siemens Creator
@HoangDQ,I enabled the ssh service for my binded mindapp, but still can't complete the ssh tunnel configuration. I would like upload some screenshots, pls kindly check.
Step1. had bound the db instance with my mindapp
Step2. had enabled the ssh for mindapp
Step3. get the external access key of the db instance
Step4. ssh tunnel configuration
Hi
I have enabled ssh for app and space, still coudnt configure ssh to access postgres instance locally, cf CLI got struck when i give a command cf -L 5432:host:5432 appname.
attached screenshot ,pls help on the same
I suggest you run your command with the '-v' flag; the verbose output will show you where the issue is.
