Change variable color depending on string?
Hi
Is it possible to change the color on a variable via a method?
E.g. If a string says "Empty" then the variable is green and "Full" gives red.
Thanks in advance
Re: Change variable color depending on string?
try
&CastStatus.color:=makeRGBValue(255,0,0) --simTalk 2.0 for red, 0,255,0 for green
or
ref(CastStatus).color:=makeRGBValue(255,0,0); -- old syntax
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Thank you, worked perfectly.
