Check if FootPath is empty
I can check if a SingleProc is empty by
SingleProc.empty
But I can't check if a specific FootPath (e.g. FootPath15) is empty by
FootPath15.empty
I want to avoid sending an additonal entity to the SingleProc, if the first worker hasn't dropped off the entity at the SingleProc, but is on the FootPath going to it.
Thanks in advance!
Re: Check if FootPath is empty
Hello Engelhart,
Until we implement Empty you can use the following statement to check if the foot path is empty:
FootPath.contentsList.dim = 0
Ralf
