Cycle time calculation and cycle time improvement tarcker
I would like to know if there is a way to generate Cycle time reports for object flow operation. My use case will be sort of an assesing an assembly area where in the parts will be taken from a bin and assembled, if the bin location is moved the path is changed and I would like to know if it affects the cycle time...?
Tried the Generate Cycle time report option but it seems to be of use only for robot operations. Any help will be much appreciated Smiley Happy
Cheers
Sudhan
