Deploying Process Simulate on Teamcenter
Hi all,
I've installed Process Simulate TC on my computer and I need to deploy the package on tem.bat, however, I can't find anywhere on the documentation on how to do so. Anyone have a useful guide or steps on what to deploy?
Thanks!
Re: Deploying Process Simulate on Teamcenter
You need to deploy "Customization for Process Simulate Integration" via TEM.
Then you are able to load data to PSonTC.
Best regards
Patrick
Hi Patrick,
Thanks for the reply, I figured it out after I posted the message. To follow-up on some further details the module "Test Manager" needs to be deployed first in order to un-grey the "Customization for Process Simulate Integration". Then you can deploy that module and PS on TC will be functioning properly.
