Detailed CAD Reports
Not applicable
Do you know if it posible to grenerate a Report in Factory CAD that displays not
just name/quantity of objects in a layout, but also its attributes like length,
heith, number of bays, lenght of bays(if its a rack), etc...?
3 REPLIES 3
Re: Detailed CAD Reports
Not applicable
Hello Christian
Most of the arx objects can be reported via the XML query objects routine. The information
that is reported is based on a custom rpt file that is included when you install
the software. You can modify the report content as described in the attached document
(to create your own customized reports).
In v13.0.2 we have added new reports for the rack, mezzanine and stair arx objects.
The mezzanine reports on area and the rack reports on packable area as well as packable
volume.
V13.0.2 was released earlier this week.
Deepak
"Christian Orozco" wrote:
>Hi,
>not
Not applicable
Do you think its possible to apply this to customized .geo objects?
regards!
Christian
Not applicable
Yes, absolutely.
Deepak
wrote:
>Thanks,
>regards!
>Christian
