Documentation
Hey Guys !
I am looking for the Technomaticx Sim Talk documentation (a file ehich has all the usuable libraries and its fuction). Any suggestions, links..?
Thankyou
Re: Documentation
Hello Parag,
SimTalk is described her in the Online Help: Reference Help > SimTalk > SimTalk
If you want to know which attributes, read-only attributes or methods a specific object has, you can right click the class or an inserted instance and select Show Attributes and Methods.
This is described here Reference Help > The Plant Simulation Program Window > Ribbon Bar > Home Ribbon Tab > Show Attributes and Methods > Show Attributes and Methods
Select an attribute or method and press the F1 key to open the help for that attribute or method.
