Environmental Variables not Defined
Not applicable
I am trying to load a factory menu from a network installation of Factory Flow 10
and I receive the following message "Factory environment variable not defined."
What variables do I have to set in order for Factory Flow to work off of the network
installation.
Thank you in advance.
Re: Environmental Variables not Defined
Not applicable
Hello Daniela
It looks like the installation did not go correctly. The easiest way to fix
this is to do an un-install first and then re-installing the software.
Please give me a call if you have questions.
Deepak
515-296-9912
"Daniela Ilieva" wrote in message
news:44564c53$1@bbsnotes.ugs.com...
> Flow 10
> defined."
> the network
> installation.
