Error I need your help. / Failed to load the TSB Simulation
Dear Forum,
im a Student who is trying to generate a plant Simulation.
I´ve got a failure after i changed 1 object. But i put him back in the Simulation.
Now its impossible to start the Simulation i get continously this Failure.
Id would be such as pretty, if some of you could help me out.
With regards
Aslan
Re: Error I need your help. / Failed to load the TSB Simulation
Siemens Legend Siemens Legend
Siemens Legend
Hi Aslan,
Can you please share which version of Process Simulate you are working in?
In general it should be possible to solve this problem by following the steps shown in the video.
(view in My Videos)
If this approach does not work, it may be that you need to upgrade your PS version.
In the past (pre 13.0.2) there were  some known issues where a TSB simulation would save , but not load back ok.
Best regards,
Pelle
