Error- .psz file is invalid
this error came when i opened the .psz file which i been working on it from past week in PS standalone, i didn't change the system root from the start.
Any solutions greatly appreciated
Re: Error- .psz file is invalid
do you fixed the error? i am facing the same issue.
Please check wheather RobotsMachineDataFiles & TuneCells folders are present inside the project folder before you load .psz file.
If your project folder(to which we root PS) is missing with RobotsMachineDataFiles & TuneCells folders then .psz will not work - it will show the error saying .psz file is invalid.
thank you
thanks very much for your quick reply, yes i have delete some sealing folders. and the folders cannot be recovery. How can i recover the psz file? is there any method to reopen the psz file?
