Error while importing JT file in Process Simulate
Hiii...
I have created a simple model on NX CAD and saved it to .jt format.
Now I'm trying to import this file to Process Design but it is giving the error of  "The executable TxJt2co.exe is not found"
Need help in that....
6 REPLIES 6
Re: Error while importing JT file in Process Simulate
You need to install CAD Translator. You will find it on installation disk.
Best regards
Patrick
Do I have to install in the ems server machine or in the client machine
"I have created a simple model on NX CAD and saved it to .jt format."
If he saved the file as jt he does not need the translator!!
He just needs to connect it to the database.
As suggested by Patrick, please install cad translator in the client machine. Setup file is available in the installation kit which converts JT into cojt.
Best Regards,
Jeethan Rohan
Your Problem is solved ? If not feel free to contact.
Best Regards,
Jeethan Rohan
Best Regards,
Jeethan Rohan
My problem is solved.
I copy my parts in to the database, and after that it opened easily.
Thanku for the help....
