Factory CAD and Factory Flow ver 8.0
Not applicable
Team:
I have just been informed that the much anticipated Factory CAD and Factory Flow version 8.0 has been released. Our customers should be getting their copies in the mail in the next couple of weeks or so - depending on how quickly our Distribution department can manufacture the CDs.
This version of the Factory products has a whole host of new features. Most notably, Factory CAD has a brand new XML System Builder, Library Manager, Clearance detection, and numerous usability enhancements in the tool in general. Let's not forget the DIRECT import of UG, Parasolid and JT data into our XML object. Truly, this is the BEST there is, for 3D factory modeling.
With Factory Flow, we've enhanced calculations resulting in over 60% reduction in calculation speeds. Also, with the ability to selectively perform calculations on user selected part numbers, and it's brand new reports, this new version is very cool.
Shree Moorthy
3 REPLIES 3
Re: Factory CAD and Factory Flow ver 8.0
Not applicable
Shree,
Does Factory CAD read native Solid Edge Assemblies yet?
I know there is JT output that can be read in, but wondered if there was a direct read option yet.
Tony.
"Shree Moorthy" wrote in message news:3f297484@bbsnotes.ugs.com...
Team:
Shree Moorthy
Not applicable
Tony,
Other than jt (Direct Model) read and write, Factory CAD currently reads in prt (UG) files, xt (Parasolid) files, and wrl (VRML). We're have plans to read in Solid Edge data; but it is not there yet.
Shree Moorthy
"Tony Jolly" wrote in message news:40459043@bbsnotes.ugs.com...
Shree,
Tony.
Team:
Shree Moorthy
Not applicable
In Factory CAD v 9, support was added to read SolidEdge and convert to xml
objects using the same import parasolid command from v 8. We read SolidEdge
par, psm, pwd, and asm files.
Shree,
Tony.
Team:
modeling.
Shree Moorthy
