FactoryCAD Error 115018
Hi All,
I keep getting an error trying to open a .DWG file on my computer. The error message is as following:
115018: You need to install a newer version of the Factory Products.
I am currently using AutoCAD 2014 with the FactoryCAD add on. The file was also worked on by another user on a computer with AutoCAD 2015 without the FactoryCAD add on. I have also tried opening the same file on a different computer with AutoCAD 2014 and it opens fine without error message. So it seems to be an issue with my version of AutoCAD/FactoryCAD. Has anyone encountered this error message before?
Thank you for any help in advance!
Kind Regards,
Nathan
