FactoryCAD install
When I attempt to install the current install of FactoryCAD it does not detect AutoCAD 2018 and will not install. How can we remedy this?
Re: FactoryCAD install
Siemens Creator
Factory 2018 adds support for AutoCAD 2018. This is now available for download.
If you are trying to install FactoryCAD 2018, make sure you are using below compatible platforms
Microsoft Windows operating systems 64 bit versions for factory 2018
• Windows 10 (64-bit only)
• Windows 8.1 with Update KB2919355
• Windows 7 SP1
Note
Release 2017 and 2018 no longer support 32-bit operating systems.
Autodesk packages, as supported by Autodesk on the underlying operating system
• AutoCAD 2017 and 2018
• AutoCAD Architecture 2017 and 2018
• AutoCAD MEP 2017 and 2018
Best Regards,
Jeethan Rohan
Best Regards,
Jeethan Rohan
I believe you got what you are looking for
Best Regards,
Jeethan Rohan
