FactoryFLOW Release 2013 'Use Local Activity Assignmnet' doesn't work
Not applicable
I can create new Activity Equations and Activity Templates.
I can select select my new templates for Load/Unload, but the Flow Calculation uses the templates which I selected when I created the Material Handlig Device.
Regards Magnus
Re: FactoryFLOW Release 2013 'Use Local Activity Assignmnet' doesn't work
You should select your templates in Material Handling Device for correct calculation.
Best regards
Galiya
