FactoryFlow splitting the flow by percentage not working
I'm experimenting with FactoryFlow. I tried to split the materialflow of my assembly and parts.
When i type in the percentage in each move-arrow, it seems to work. But when I chose an other part or assembly, all the adjustments are gone, and the failure appears: "the sum of all move-arrows must be 100%"
Is this a bug of Factory, or do i have a mistake in my model?
I am using Factory 2016.
you can find the file attached.
Thank you in advance for your answers
Re: FactoryFlow splitting the flow by percentage not working
Siemens Creator
I tested your file in FactoryFLOW V2016. I was able to edit the move percentages in both the Move Properties and the Part Routing definitions below without any issues. As long as the move percentages totaled 100%, I did not receive any messages. Clicking on another part or assembly did not impact any changes I made to the move percentages. File with updated move percentages attached.
When i opened your file without changing anything and i klicked on the Foot Assembly the same problem appears.
All values are put up to 100% and the message that it hast to bee 100% appears.
I do have a student, who has the exact same problem.
Is it possibile that we do have a different version of AutoCAD or Factory?
I'm using AutoCAD2016 and Factory2016. I didn't do any changes of the properties.
Thank you for your answer.
Siemens Creator
Same versions of the software. Are you working with English install/OS?
No I'm working with the German install (both AutoCAD and Factory) and German OS (Win 8.1)
I just tried the english version of Factory 2016. It is working now. I can change the values of the percentage split.
It seems to be a problem with the German version of Factory2016.
Tank you for your Help!
