Do you mean
Reply
File Client Cache is not enabled
I am getting the following error which appears to keep the viewer window from working.  I am using the 4-tier thin client Chrysler install of Teamcenter 8:
"File Client Cache is not enabled.  Please contact your System Administrator"
How do I enable my file client cache?
Re: File Client Cache is not enabled
FMS_HOME in your envrionment variables  needs to be set.
I tried resetting the FMS_HOME in the environment variable. After that FCC services are not getting started...getting the attached error
