Find "3D File" field in Table View in Process Designer 10.1
Hi all,
Can someone support me to find the field for "3D File", found under the Physical Tab, for a PartPrototype? I cannot manage to find it..
Best regards,
Henrik
Re: Find "3D File" field in Table View in Process Designer 10.1
Hi Henrik,
You need to configure for Partprototype
ThreeDRep->File->FileName, this will show the same thing as in the properties under 3D File.
Best regards
Martin
Thank you Martin!
Do you know if there is the same possibility for an instance of a prototype? (Can I find the 3Dpath for the prototype if I use the table view on an instance?)
Best regards,
Henrik
