How To map signal between PS Signal and Rockwell signal Tag in Kepware OPC?
I am try to map the signal between PS and Kepware (Rockwell), but seems it can not, I have been map successfully between PS and KEPWARE (SIEMENS).
Re: How To map signal between PS Signal and Rockwell signal Tag in Kepware OPC?
I think you are using OPC UA/DA connection type, correct?
In the connection itself you will find a "ItemHeader".
Please try to put "BS010.BSR10." in here.
You can also try to use an other OPC client to see what is transferred from OPC server.
E.g.
OPC DA -> Kepware OPC client or Power OPC
OPC UA -> UA Expert
Best regards
Patrick
