How to assign parameters to individual entitys
Sorry if this has been posted already, I'm fairly new to this forum.
As you can see in the picture, I have two identical operations in series. I'm having trouble efficiently sorting the entities between the two operations. I have it set up to sort at SingleProc11 but I'm wanting SingleProc1 to detect if the entity has already passed through MBHPressOne. Is there a way to assign paramaters to the entities individually?
Re: How to assign parameters to individual entitys
Honored Contributor
Honored Contributor
First: there is a special Plant Simulation forum, it is better to post your questions there
You need two steps: the attributes you can add in the MU in the class library (tab user defined attributes)
In the exit control (rear) of the press you can set a value --> this you can use eg. in the tab exit strategy --> MU attribute to select the right successor
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Thank you for your response. I'll post future questions in the PlantSim forum.
I followed the steps you listed, however the MUs still aren't taking on the value of "true" after they leave MBHPressOne. I added an attribute in the class library under the user defined tab, then I went to the exit tab on the MBHPressOne and on the dropdown I selected MU Attribute. I then clicked Open List and added my user created attribute from the MU. I set the value to true on that attribute.
What have I done wrong to prevent MBHPressOne from changing the value from "false" to "true"?
Honored Contributor
Honored Contributor
can you post your model?
Steffen Bangsow
web: www.bangsow.eu
I posted a screenshot of my model in the original post, if that's what you are referring to.
Honored Contributor
Honored Contributor
if we want to check, what is wrong with your model, the spp file is more helpful
Steffen Bangsow
web: www.bangsow.eu
Here is the spp file. It's not very organized, I'm still fairly new to PlantSim
Honored Contributor
Honored Contributor
you made only one half
If the MU passes the first press,you need set your attribute to true --> then it works
Steffen Bangsow
web: www.bangsow.eu
Right, that's what I don't know how to do.
Honored Contributor
Honored Contributor
have a look into the model, I have done it
Steffen Bangsow
web: www.bangsow.eu
