How to make supercomponent in Process simulate?
What is the command for giving kinematics for supercomponent to create different poses?
Re: How to make supercomponent in Process simulate?
In PS you have "Kinematics Editor" and "Pose Editor" to do this.
Best regards
Patrick
It is possible for one component...I think
What If there are several units of perticular components and each units have individual kinematics.
Please see the attachment showing different units of single component.
In this case you should have an "Equipment Prototype" as parent for all your clamps.
From your structure in Object Tree put all clamps under "FIXTURE" into an "EP".
You can open the Kinematics Editor for the EP as well.
On EP selected you can also open the Pose Editor and you can select the poses for each clamp.
So you can simply build the different steps of you fixture.
Best regards
Patrick
Dear Patrick,
Thank you for your information.
I have tried as per your instructions but Pose Editor option is not activated for EP.
See the attachment
Thanks in advance
You need a dummy kinematics inside your EP.
Custom create two links and a joint between.
As long as this is not available the EP is not interpreted as device.
Best regards
Patrick
Hello Patrick,
Thank you so much for your support.
Hello
can you please tell me the advantage of EP
