Import 2D Layouts in RobotExpert
I have problem with import 2D layouts in RobotExpert, because i have 2D layouts only in extensions *.dwg, *.dxf, *dws, *dwt. How can I import that to RobotExpert ??
Re: Import 2D Layouts in RobotExpert
RobotExpert does not support these file types. You can import NX, JT, SolidEdge, SolidWorks, ProEngineer, CATIA, Parasolid, STEP, IGES, Tecnomatix files "only" Smiley Happy.
Dave
Do you know some, simple converter fot this types?
Because, I would like to avoid using AutoCad etc.
I am not sure, but you can try SolidEdge Drafting. It is for free - http://www.plm.automation.siemens.com/en_us/products/solid-edge/free2d/
All other products I know are for money.
It should import AutoCAD files and it should be able to export IGES.
Let me know, if it helped.
Dave
Solid Edge Drafting can't export file to AutoCAD types, but i found some simple program "FreeCAD". It's totally free also and in this program it's possible to export *dfx to *.igs and *.stp.
So i think case is closed Smiley Happy
it was misunderstanding. SE Drafting just imports ACAD files (DXF, DWG) and it should be able to export IGES, that you can directly import into Tecnomatix products. Exporting to DXF is useless for Tecnomatix.
Anyway, I'm glad that you have found a solution for your problem.
Dave
I understood you. I import *.dwg file to Solide Edge Drafting but it's impossible to export *.iges etc. files in this program.
