Import CAD files
Hi all,
I am not getting the import CAD files option in the File TAB of Pocess Simulate, I am using version 11 of Technomatis. Please find the below attached screenshots.
Re: Import CAD files
Hello Ibrahim,
The command "Convert and Insert CAD Files.." is in the "Data Administration" category of the Customize dialog.
But as there are some other missing commands in your image. Try to set up all of them at once with the Layout Manager (Select the menu View / Layout Manager and double click in the Standard layout).
I am also unable to import CAD files into my study. I don't even have "Convert and Insert CAD files" option in the Customize dialog. I have searched under "All Commands" too but there is no option to import CAD files. Can you please help me with this issue?
