Kawasaki Auxiliary File
Where can i get the kawasaki auxiliary file.
Re: Kawasaki Auxiliary File
You are using Robcad/Process Simulate?
Software Version?
Best Regards,
Jeethan Rohan
Robot Expert 13.1
It will be under .ce folder
Find the attached image
Best Regards,
Jeethan Rohan
You got the location?
Kawasaki RCS version you are using ?
Best Regards,
Jeethan Rohan
without RCS where can i find this file
I used the default AUX file for simulation but unable to set the speed and accu for each point.
I believe you are using process simulate for the snapshot ?
Best Regards,
Jeethan Rohan
