License problem- Tecnomatix 15
When I am trying to start Tecnomatix 15, I am getting this license error message"Cannot launch application-license not found. Plerase consult your system administrator". But version 14.1.2 is perfectly working with my license server.
Why is this happening? Do I need a newer license version?
Adrian
Re: License problem- Tecnomatix 15
HI,
For PS15.0 you need a new license.
When 14.1.2 is running your license is for V14 only.
You can check yourself, of the lic file and in your packages you should see somthing like "...ugslmd 14.0".
Here the 14.0 is the indication for V14.x only and before, but not for 15.0.
Best regards
Patrick
