LogicBlock Expression via .net API in Process Simulate12.1.3
I was trying to create a LogicBlock in Process Simulate12.1.3 via the .net API and everything worked except that I can't create an Expression (TxPlcExpression). Is there something I'm missing?
Thanks and kind regards,
Mario
Re: LogicBlock Expression via .net API in Process Simulate12.1.3
ok, I found it: TxPlcExpressionBuilder has to be used to generate new Expressions
