Machine configurator error
Hello, has anyone had this problem when opening Machine configurator ?
Richard
5 REPLIES 5
Re: Machine configurator error
Hi!
Do you have a solution currently???
Regards!
hello friend, it has already been corrected, thank you very much.
Hello Richard,
I have the same problem currently, do you remember what was the solution in your particular case? can you share it with me?
Regards and thank you in advance!
Hi Raul_Ramirez.
The PC was formatted, and everything installed again.
Regards!
Hi Richard!
It was solved few minutes ago, ... midterm solution... I can run the program with administrtor priviledges otherwise I get the JET RUNTIME error. Is not the best solution but is working by now... for some reason my user is not able to run some of the files required by JAVA but I was working fine few months ago. By now this solution is working for me Smiley Happy.
 Thank you very much about your answers!
