Method Failure
Hello
i`ve got a question. I wrote this method..but it doesnt work (syntax error).
Could you please help me to find my failure?
is
do
    if ?.nf(1).belegt=false
    then ?.inhalt.umlagern(?.nf(1));
    elseif ?.nf(1).belegt=true and ?.nf(2).belegt=false
    then ?.inhalt.umlagern(?.nf(2));
    elseif ?.nf(1).belegt=true and ?.nf(2).belegt=true
    then waituntil ?.nf(1).belegt=false;
        @.umlagern(?.nf(1));
    end;
end;
Thanks and Best regards
Konstantin
Re: Method Failure
nf is a method, you cannot use it inside of a waituntil statement, but you can use a object variable to avoid this
is
n:object do if ?.nf(1).belegt=false then
?.inhalt.umlagern(?.nf(1)); elseif ?.nf(1).belegt=true and ?.nf(2).belegt=false then
?.inhalt.umlagern(?.nf(2)); elseif ?.nf(1).belegt=true and ?.nf(2).belegt=true then n:=?.nf(1); waituntil n.belegt=false prio 1; @.umlagern(n); end; end;
Steffen Bangsow
web: www.bangsow.eu
mail: steffen@bangsow.net
Re: Method Failure
Thanks Steffen! Its working.
