PD xml import error
While importing an assembly file (.jt) using process designer, we are facing issues in loading the data. It gives a error message as shown below.
we are getting all the data as individual .cojt in the assigned folder and gives message stating "Full assembly conversion finished successfully" in the log file.
Please let us know how to solve this issue to load the component.
 thank you
Re: PD xml import error
in general RE is not intended to cooperate with PD. For this purpose PS should be used.
Anyway, RE could import a JT file. Could you provide the problematic file?
Dave
Hello Dave,
The above error message is displayed while trying to import the CAD files (both NX and .JT formats) into Process Designer to be later used for simulation in Process Simulate.
We are not using the Robot Expert application.
The error persists only while importing an assembly file structure.
Monolithic files are imported with ease.
The error message points to an "unexpected start tag" in the .XML file.
I have attached the .XML file for reference.
regards,
kiran
sorry for my fault. I do not know what is the problem source in this case. I have never come across any problem during assembly import.
Are you using newest version of TX?
Dave
Hi Dave,
we appreciate you taking out time to help us. thank you.
we are using the TMTX 11.1 version in our clients and server machines.
we have not updated to the version 12 in our systems.
regards,
kiran
issue resolved when CAD translator downgraded to v3.1 with hotfix.
