Pack and go
Hi
Please let me know does it possible to automate the Pack and go option in tecnomatix plant simulation.
Can we close the model and save in the .exe in some folder (give by the user) through pack and go option by SIMTALK ( END SIM method of tecnomatix plant simulation).
Amar singh
3 REPLIES 3
Betreff: Pack and go
Hello Amar singh,
You can start the PackAndGo.exe in the installation folder. The first argument is the model file and the second the name of the executable file which will be created.
This can then be triggered by the system function through SimTalk.
Ralf
Hi Ralf,
Thanks for your reply.
Please let me know the system function which could be possible through SIMTALK.
I am unable to use pageandgo.exe filename
I have used the attached code, but still doesnot work..please let me know alternate way to do it.
Amar singh
A space between model and file name is missing:
local modelName:string := "E:test\test.spp";
local exeName:string := "E:test\test1.exe";
local exePath:string := applicationHome + "PackAndGo.exe " + modelName + " " + exeName;
system(exePath);
Ralf
