Pan Sensitivity
Is it possible to alter the Pan Sensitivity within Robcad? It's a bit slow for my liking...
Re: Pan Sensitivity
Siemens Legend Siemens Legend
Siemens Legend
Hi.
You can try to create a new .robcad file in you $HOME directory, and try this parameter with different values:
PARALLEL_VIEW  0, 2.0
  Arguments: delta, factor .
  Those values set threshold ( delta ) and sensitiveness (factor) to mouse movement at time of parallel viewing.
Otherwise, use the Exceed Configuration tool to adjust Screen 0 Panning value under "Display and Video".
Ray
